I have a situation where I need to anchor something at the edge of a slab and space is at a premium...
I was thinking of placing dowels into the vertical face of the slab (about 10" thick) with epoxy, placing a plate with holes over the dowels and plug welding the plate to the dowels. I'm limited in the space I have at the slab edge to the point where I only have the room to put a 3/4" plate (no room to bolt the plate). I can extend my plate along the length of the slab to get the number of anchors to suit the loading.
This isn't so much a question, just wondering if anyone can see anything wrong with this idea, or has any success/failure experience with this.
I plan on contacting Hilti and asking about the affect the heat of welding will have on the epoxy.
Like I said, I have flexibility with the anchors so there is no specific load I'm working with yet...but it is in the range of about 5000 lbs tension/shear.
