Epicyclic Gear - Tooth Mesh Vibration Frequencies
MachEng
11
I am creating a fault frequency set for analysis in a condition monitoring program on a compressor driven through an epicyclic gear increaser. My request is for the formulae to calculate the tooth mesh frequencies in this type of gear assembly and any other useful tips regarding this type of machinery. The components are as follows:
Output HP - 7100 bhp
Gear ratio - 1:2.6207
Low speed annulus - 112 splines
annulus ring gear - 76 teeth
Star/Planet Wheel - 23 teeth
Sun Wheel - 29 teeth
Also are there any links/web sites that can give me more information regarding epicyclic gear fault frequencies?
In anticipation of your interest and comments thanks !
Macheng
DANIEL C. SMAISTRLA
daniel.smaistrla@santos.com.au
Equipment: Centrifugal Pumps and compressors; Steam and Gas Turbines; Reciprocation Engines and
Compressors
Specialties: Vibration & Piping Pulsation analysis, Root Cause Analysis and Condition Monitoring
Everyone,
I forgot to include that the gears are double helical.
Macheng
DANIEL C. SMAISTRLA
Compressors
You can download a demo of the VCI Gear Calculator program at that will perform the calculation you need. The download is free and the demo will run ten times, after that the program is relativity inexpensive (less than $200 US). If you have any problems let me know. I'll be glad to help.
