Q
Quick Karl
Guest
Here is a problem that has me stumped
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Mihail said:Hellow !
I think that the Michel's idea work. But not very well because you make a normal projected view from a plane shape to a cilindrical surface.
Assuming that the high of the text is not bigger than the diameter of the pipe, try that:
Make a new part. This part is"pipe" froma very thin sheet metal (0.1 or 0.01 mm). The cross section for new "pipe"is asmall line followed byanarc (180 degree is more than enoutgh) and the radius is a bit grater than your pipe. The small line create a small surface and this surfacewill be necesary for the UNFOLD feature wich ask youfor a fixed face.
Unfold this "pipe", make a cut with the logo sketch, then fold the "pipe".
Make an assembly with your pipe and the new one, and save it.
In the assembly make a plan as "parallel" as possible with the logo (now you can see well this logo) somewhere outside of your pipe, EDIT PART (your pipe) and EXTRUDE CUT. As plan for the sketch choose the plan you created.
Select all the logo's edges, convert entities, and exit from sketch.
in theEXTRUDE CUT feature managerchoose OFFSET FROM SURFACE option, set, as surface for offset,your pipe surface and... that is all to do.
Note that EXTRUDE CUT feature do not allow you to create multiple bodies, so you must work around your logo before try to cut the new "pipe".
I think that is easier to use surfaces instead a very thin sheet metal but I don't know (yet)to work with surfaces.
Hope you understand my english because I am not enough skilled to speak so much![]()
You can email me at ALT.MIHAI@YAHOO.COM and I'll send you the files I created to solve this problem.
Good luck !
Mihail said:As "parallel" as possible: In your picture, Ox is axis for tube. Assuming that your text is along the pipe and the middle of the text is in plane Oxz, the plane "as parallel as posible" is Oxy. Or any plane parallel with this one. I say "as parallel as possible" because your text is on the cilindrical surface and a plane is... a plane.
I try to teach you HOW TO engrave the tube in SW. How to make this in realliti... I do not know. But, I think, youuse CNC machineto engrave the logo. And the CNC machine'ssoftware can read your SW file (maybe not .SLDPRT butin other format as .IGES)and perform automaticaly the task.
Sorry, I can not provide more help in this directtion.
Is quite simple, in math, to perform the projection for a line on a cilindrical surface. You must calculate the position for 2 points. But, if you are not an old chinesse, you can not calculate the projection for eachline or curvefrom your logo. So you must use a software to do this.
Good luck !
JohnnyRetro said:If you have SW2009, use the "Project Curve" feature to
project a single, open or closed curve on a surfuce.You
might have to do this a few times if you have a complex
logo. When the curve is projected, you can use thse
"Cut-Sweep" feature to cut out the logo. Hope this
helps.
