Engineering Department Woes...What to do? 8
dmech
Hi Eng-Tips Forum,
I have considerable engineering experience (BS + MS + PE + 15 years on the job) and have worked for a handful of companies. Recently, I was hired to work for a small company with a relatively new engineering department. Our manager holds a physics degree and is smart. However, he lacks engineering experience and a general understanding of engineering best practices (e.g. engineering documentation, accurate BOMs, Engineering Change Process, design reviews, development process, coordination with other departments, part numbering system, etc.).
In addition, the most respected "engineer" in our small company lacks any sort of degree, but has taken chemistry, physics, calculus and is generally pretty sharp and knowledgeable on our products from her technical support experience. However, she lacks knowledge in engineering best practices (see partial list above) and basic engineering concepts (e.g. single shear vs double shear, fatigue calculations, Free Body Diagrams, Statics, Dynamics, detail drawings, etc.).
Both are respected by the CEO for helping CAD design the products and build the company. Also, they are distantly related to the CEO by six degrees of separation.
Soon after I was hired I wrote the engineering manager an e-mail on some basic systems we should put in-place to organize ourselves (e.g. formal part numbering system, BOM management system, ECO and PDM system) and prepare for growth. Also, I suggested we fully document our products in 3D CAD, as well as the associated engineering documentation and specifications. That was a year ago and nothing has changed...not a single thing!
How can I improve our department without stepping on toes of the engineering manager and the highly respected "engineer" and actually effect change?
Thanks,
DMECH
Short answer; You can't.
Longer answer:
You can't do it without stepping on toes.
You probably can't do it even _with_ stepping on toes.
Obvious questions:
Why were you hired?
What does your job description include?
If. e.g., you were hired to 'clean up the mess', you may not live long enough, even if you are younger than your experience suggests.
If, e.g., you were hired to 'solve a few problems with the product(s)', you may be able to make a tiny bit of progress, but it will be slow and frustrating.
The fact that not a single thing has changed suggests that the entire hierarchy above you believes that not a single thing is wrong. Those in the hierarchy below you will probably have a good deal to say about what is wrong, once you have gained their confidence, if you can do so. They are powerless to change things, of course, and have learned to trust no one, especially newcomers, so don't expect much cooperation until you have demonstrated that you can and will maintain their trust.
You might be able to justify the necessary changes on a purely economic/business basis, and that probably is the only way to force the expenditure of any money, but there are hazards that may not at first be apparent.
Chances are that the company uses an accounting system that systematically hides actual costs, making it near impossible to say what any particular defect in a product actually costs. Chances are that the system evolved this way, and no malice was intended.
However, there is also a fair chance that someone has figured out how to game the accounting system to their advantage, so you may encounter apparently illogical resistance to even giving you access to the data that you might logically need in order to justiy improvements, much less make changes or additions to the system so as to provide better information for your purposes.
There is also a strong possibility that no one there even knows how to effect even the simplest change to the accounting system, that no one person knows how all the modules work together if they do, and that the system users will scream bloody murder if anything changes in their portion of the user interface, which is probably undocumented and grotesque.
Can you get your old job back?
Mike Halloran
Pembroke Pines, FL, USA
Personally my initial reaction was that anybody who puts scare quotes around 'engineer' when that engineer has obviously designed some successful products from go to woe may have a bit of an attitude problem.
I've been dumped into a similar situation twice, and both times my suggestions were at least partially implemented by the time I left. If a 19 year old can persuade a rusted on department to change its business practices I'd have thought an experienced person would be able to find a way.
There are many threads in this and other forums on a similar theme, usually written by bright young things straight from uni. Read them and have a think.
Sadly, and taking the opposite tack to the above, if may be a case of 'if it ain't broke don't fix it', so it may be that there is no real motive to change things.
Cheers
Greg Locock
Mike, I was oblivious to the mess when I was hired, but I immediately realized the lack of engineering best practices by the end of my first month, when I was told there wasn't a complete and accurate BOM, CAD models, or any associated documentation for the products. I must say, it is painful to watch the dysfunctional operations side of the business crawl along because accurate BOMs and engineering documentation are non-existent.
I hear grumbling below and have come to find that many of the other departments have a general disrespect for the 'engineering' department because we are perceived as not doing much in the way of fixing or innovating (consumed with production support and firing fighting). Also, you're dead-on point about the accounting system; no gaming but it would be impossible to understand the financial impact of defects.
Greg, I can understand your initial reaction given the information in my post. However, some background might help explain the use of "engineer".
A component grinds itself to death well before it should, a certain option has a 70% failure rate in the field, catastrophic failures have nearly injured customers and have the potential to fatally injure the customer, a key operational component is not constrained correctly (inducing slop), vibrations within the operating range of the product deteriorate quality, use modes are complicated and lack documentation requiring intense technical support, products are returned, and I could go on. All this has lead to a technical support department two to three times the size of engineering, among other inefficiencies.
Request to eliminate these issues or improve the product are met with the following logic.
CEO: "If something were wrong I wouldn't have been able to sell as many as I have, right "engineer"? (who's technical opinion I trust the most)
'Engineer': "Yeah, I don't see or have any problems with the product lines."​
That's the story of the attitude problem you sense and you've correctly identified the root cause; 'if it ain't broke, don't fix it'. In this case, that saying depends on who you ask; an engineer or an 'engineer'. To say the least it's a difficult and frustration environment for an experienced engineer. However, I care about the company, like my coworkers, and I want to affect positive change. I'm just at a loss as to how to navigate the waters.
Cheers,
D
Start with money. Find the most expensive on-going money pit product in terms of after-sales, whether that is in terms of warranty or tech support, and fix it properly. Make sure you track the cost benefit analysis.
Do that a few times in two years and people will listen to you. Or else you'll be kicked out, but that seems unlikely.
Setting up a 3 way confrontation isn't going to work, as you've found, as they'll go on the defensive and block you. The best bet would be to work /with/ the 'engineer', not around her.
Cheers
Greg Locock
There's a couple of recent threads here
which I can't bear to read again but I'm sure the usual contributors make some salient points.
I'd be the first person to agree that I tend to work /within/ the existing system (except for technical solutions) rather than trying to change the system, therefore my perspective is fairly conservative organisationally. Technically I will push the 'correct' solution up to (and occasionally beyond) the point where I get told to shut up.
Cheers
Greg Locock
As engineer of a different domain, my first problem with this kind of situation is an Ethic one.
I cannot work in these conditions (lack of good practice) while engaging my professionnal responsability !
In my field, I cannot close my eyes on problem like this because public casualities can result of it !
"As engineer of a different domain, my first problem with this kind of situation is an Ethic one.
In my field, I cannot close my eyes on problem like this because public casualities can result of it ! "
That's why it's called the 'Whistleblower's Dilemma'. The combination of a backbone and a conscience can put you on a collision course. Best of luck. Try the professional ethics in engineering forum here.
GregLocock had some good points.
Have you considered the fact that maybe they are a little intimidated by you and your experience and therefore are reluctant to listen to any of your ideas? I have met "them" many times and pride is usually the culprit. You should be sensitive to the fact that they also know they don't hold an engineering degree. This may be a problem for them in trying to listen to you.
One other I'd like to suggest is a phrase my old English teacher taught us which was "if it is to be, it's up to me". I'm not suggesting you go lone wolf and proceed to act as though you are own boss. However, if there are things you could do that might demonstrate your expertise, that might be the ticket to getting your ideas listened to. These other folks probably are not interested in making themselves or their operation "better". They just want to keep the wheels turning. So if you are able to bring some solutions, actually bring the solution not the idea, then you show them that they actually do a have problem that can be solved. They may be pushing back to you because they don't think any of your ideas will help...once you show them that they do, that might help get more of your ideas listened to.
PE, SE
Eastern United States
"If a builder builds a house for someone, and does not construct it properly, and the house which he built falls in and kills its owner, then that builder shall be put to death!"
~Code of Hammurabi
Hi dmech
I can see from your post that you genuinely care about what is or isn't happening and I can sympathise from some of my own similar experiences.
As others have said you need to try and work with these people and try to get them to understand the problems you see.
I've noted a couple of things from your post first one:-
"Soon after I was hired I wrote the engineering manager an e-mail on some basic systems we should put in-place to organize ourselves (e.g. formal part numbering system, BOM management system, ECO and PDM system) and prepare for growth"
A better approach might be to go and discuss the suggestions with him first.
Second one:-
"In addition, the most respected "engineer" in our small company lacks any sort of degree"
If this type of thing comes across when you deal with people face to face then you are in for a long and hard ride.
Listing your qualifications in your post and then pointing out that others don't have a degree gives the impression that only people with degree's are worthy of doing the job which is certainly not the case, all any qualification means that you should be better equipped to do the job and not that you can actually do it.
Some of the greatest engineers never had degrees. Marc Brunel, George Stephenson (was illiterate), Trevithick and many more.
desertfox
Dmech, unless I have misunderstood what you have said, your core problem now is this:
YOU WERE NOT HIRED TO FIX THE MESS.
Figure out what you _were_ hired to do, and start doing that.
Your suggestions for product improvement are being misinterpreted as criticism, possibly even as insult. STOP making suggestions, especially by email.
When, and only if, someone asks you for advice on some technical issue, seeing as how you're degreed and all, be generous with your time, help them as much as possible, and >>>let them take any credit that's due<<<. Eventually the word will get around.
Mike Halloran
Unfortunately, you may need to talk with your manager & CEO and ask "What am I doing here if you won't listen to my PROFESSIONAL ENGINEER'S opinion." Clearly state why these item MUST be addressed, and that you may need to leave if the critical ones (e.g., potential harm to the public) is not addressed. It may take you having to threaten to leave before they take you seriously.
I agree that some of the items you've listed will make the business operate more efficiently, but these items need to take the back burner to the safety issues. Your job is harder because you need to teach some of the others in your department basic engineering concepts, but based upon the information you've provided, they should pick things up quick. Ask them if they want to be responsible for hurting or killing someone because they made a mistake that could be easily fixed.
Finally, when it comes to trying to make a change; show the people how change can be good. Try making up 3 fairly complex LEGO structure with about 20 pieces. Get the CEO and other engineers to try an duplicate any of the structures in the following way:
1. All of the pieces are jumbled together (and there are extra pieces) & all they can do is see the finished model
2. Pieces are separated in different compartments, given written instructions on how to assemble, and the only see the finished model
3. As 2, but you give drawings or show steps for assembly of the structures.
I think the examples and showing how they fit in your recommendations on how to make things more efficient may go farther than to tell them that things need to change.
I had a situation similar to what you described. As a new employee, I was assigned to build up a huge sub-assembly for a marketing demo unit from parts sitting around the parts room. No assembly notes from the previous guy who had left, just a parts list with many errors. Being a diligent engineer, I recorded every assembly step, including design changes which were required to get rid of the jury-rigging evident in the first prototype. (Engineers did all the building. There were no technicians). The additional time it took to record and create this basic assembly instruction made the boss angry. Soon after, I was assigned to design a huge system with motor drives, generators and battery charger. I had designed something similar for a different company. It was an 18 month project requiring 4 engineers. He was angry this time because he wanted all the schematics done in 3 weeks. Oh, and don't use feedback control theory and "fancy words" like that.
It was then I realized I was wasting my valuable time working for a goofy person who is incapable of listening to the experts. After 3 years they still have a huge software problem on wheels which has never been reliable.
Doesn't matter to me; I quit and got a much better job. It's their problem, not mine.
If you quit, they will still be goofy but it'll be their problem, not yours.
As desertfox says, one of the worst ways of communicating is email. Other bad ways include tattooing and semaphore. Carrier pigeons also suck.
If someone emails me a really gnarly question that I can see might take months to solve to little real value, the first thing I do is get off my fat arse and go and talk to them. Or at least phone them. I think that if you want to re-engineer the business (I hate that phrase) then you need to be talking to people, not emailing them.
All that being said I don't see the situation is hopeless, because the organisation doesn't sound like it is in a death spiral, so positive changes should be received positively so long as you haven't trampled all over people to get the result.
Cheers
Greg Locock
Dmech:
How on earth has this company managed all these years without you. Do remember, they have successful products, have been employing people, paying wages and bills, and showing a profit for years, without you. So, as a newcomer you may have to tread a bit lightly, they may not have thought you were their savior when they hired you. I’ve known a number of people who were not college educated engineers, but had plenty of experience and darn good engineering abilities, minds and judgement. I’d do engineering with them any day, and let them do engineering for me. I’ve also known a bunch of engineers with M.S’s. and P.E’s. who I wouldn’t want doing engineering for me. You’re never going to get anyplace with your ideas if you can’t sell them to the people above you and those around and under you. Ask your boss if you can present some ideas which you think would improve the operation. Some of the other depts. which engineering is causing to have difficulties should be your allies. Maybe you have to be the teacher and show them all the merits of what you are suggesting. One step at a time or you’ll overwhelm them. Show them how it improves their operation, saves them time, money and liability and you will likely make believers out of them, but don’t be too pushy to quickly. Use your ideas in your own work efforts; show them how a BOM or written assembly procedure would have saved them that last $1000 service call; show them how this whole group of ongoing problems could be eliminated; be the boss’ best problem solver; by example, one incident at a time, not by force feeding, or certainly not by e-mail.
Trueblood
Whilst Email may be a bad way of communicating in some situations, it does leave a record that can be referred back to. It effectively nips the " I never said that" animal in the bud.
I had a boss like that once who would deny to your face that he said something 20mins earlier, so I started printing up a "Minutes of meeting type document" as soon as I left a meeting with him, saying (Is this what we discussed ?), he would " correct" it and send it back to me. But it did stop that particular trick.
Anyway I know this is off subject so delete it if you must.
B.E.
Berkshire I agree with you about emails being a record a what was said and I do it all the time but only after I have raised concerns about something face to face with people and its a serious issue.
Sadly there are always people who deny being told anything usually associated with the Non stick Teflon coating they wear over their suits or sloping shoulders syndrome either way you learn which characters you can and can't trust.
So even in this case if all other communications of safety fall on death ears then an email would be appropriate.
Paper trail dosen't matter, we have even had signiture pages for documents, and still they clamed we forged there signitures.
It's not a game, either you work with them, or you'll be out the door.
And maybe this job is not a good fit.
cranky108
I wonder if they would claim the signatures were forged if the issue went to court?
I'd agree with you, but documenting some discussions does nobody any real good. Locker rooms are one place this is so. I'd elaborate more, but somebody doesn't agree with me, so I'll stop here.
