rpmag
Automotive
- Oct 15, 2004
- 105
I am in the process of making an attribute mockup of a individually constructed vehicle. I will be using a Mitsubishi 6G75 V6 engine and 5 spd manual gearbox. To get the drive output to the height I require I need to raise it 45mm. The simplest means is to tilt the engine/gearbox 12 degrees forwards. Obviously I will need to check the sump pickup and gearbox oil levels, but does anyone foresee any other problems?
