New2FE
Aerospace
- Sep 30, 2010
- 7
Hello anyone Im new to FEA and I am trying to work a few things out.
I understand that when you know what your applied loads are, and F=KX, the displacement can be calculated using KinverseF=X applied to a reduced stiffness matrix (where zero displacements are 'eliminated' from the stiffness matrix). Then once you know the displacements you calculate F=KX on the full stiffness matrix to get the reactions.
So how does one go about workind out what the forces are if you enforce a displacement. For example I have a simple cantilever with an enforced displacement at the tip.
