Dear Aswiersky:
For that job size, and if you want to learn, you can do it. I do not want to get into legal lingo here cause I do not want to.
The Department of Energy has two versions of a free software called Rescheck, you can google it. An option for Commercial Structures is called Comcheck. You can download it for free at the DOE's website. Its use is very intuitive so you as an engineer should have no problem in figuring it out.
I have learned to do many things that many told me not to try, and feel comfortable now doing them as long as the public safety and welfare are not in jeopardy. Just be conservative.Sometimes is useful to be practical.Use your judgement.
Make sure that you check the partition types, insulation values for wall ceiling and floor accordingly and the heat loss and gain assumptions that make sense to the are where the house is located.
By the way, you will see that the DOE assumes that even contractors can run this software and they accept the output reports prepared by them as long as the assumptions are logical and done with diligence.
