I'm designing masonry slender walls using Enercalc and I always have concerns with what it's doing.
The default load combinations for either IBC or ASCE for deflection include W only at 1.0. Which, as far as I can tell, is ultimate wind. Wall deflection should be at allowable levels, if I was doing it by hand. Florida building code allows deflection to be checked at 0.42W component and cladding, but even at 0.6W the design stops being so dramatically deflection controlled.
So two questions: 1) Is the 1.0W ultimate and why is this the default for deflection and 2) what are these code references in Enercalc? What does 25 mean?
