Whoaahhhh... I think you might be getting a bit confused here. Lets start at the beginning again.
I pointed out that En24T is not a stainless steel -it's some form of tool steel, which is what I would expect in your application.
I'm afraid that I'm not an expert in dies and materials used for hot bending/work so any advice I give can only be given on the basis of a fundamental understanding of these types of materials.
En24T (your fork steel) is a direct hardening steel. See the description in the following link.
SAE15B35H is indeed a Carbon boron steel and is capable of through hardening. It is recommended for dies and the like. Here's a link that gives some information.
In your earlier thread
thread330-83917
you recieved some good advice on various other tool steels and the reasons for choosing specific types. It seems to me that richardbuss was offering data on both those types and the advice that was given by him and TVP were sound.
The actual hardness that a material is supplied to is just one factor (usually to prevent premature wear). Other factors are resistance to thermal shock, strength, risk of overtempering at operating temperature.
You do not want a stainless steel. Stainless steels are no good for this type of application.
You want a tool steel of some description. Unfortunately it is not possible to be specific about what grade you need because as mentioned proviously in the earlier thread it will depend on the temperature your dies/tools see, what the actual operation is and possibly other factors as well.
It may be that En24T is prefectly acceptable (as well as SAE 15B35GH or ALZ H13 or D2). I don't think we can tell you precisly what you want.
This area is quite complex and I know it's difficult when faced with apparently conflicting information and not having the background as to why earlier decisions on material choice were made. Sometimes incorrect choices have been made in the past.
I suggest that you contact either Corus (if you're in the UK) or another steel producer/supplier to determine what your needs actually are based on what you are trying to do with it. Or, if you are happy that En24T fits the bill, ask your supplier to suggest/provide a similar performing material in an alternative product form, then check what they propose. You may have to heat treat after machining or may be able to machine the supplied material if it meets your service requirements.
I hope this is useful.
Andy
