Email notification after a job is complete
GeorgeEllwood
GB
Does anyone know if it's possible to get ANSYS to send an email after it has finished a job on a PC? I know this command works for UNIX machines:
/sys,mailx -s ansys_finished email@email.com
I'm running ANSYS 11 on a Windows XP machine and use Outlook for email.
Cheers
George
Yes, it is possible. I did it once and it worked just fine. But I used the command /MAIL (not /SYS) at the end of the input code. First you should read the configuration instructions in the help of ansys. Before you can send a mail with /MAIL, you must configure it with the application BLAT. You will find all the needed informations in the help menu.
Alex
