EM version of duckbill check valves in fluid flow
avoy
Aerospace
May 18, 2016
4
In fluid dynamics there is a duckbill check valve to prevent the reverse flow.
In EM wave an antenna emmits/receive at the same efficiency.
Is there anyway one can make a check valve for antenna so that it emmits more than received or
vice versa.......or perhaps emitts without even receive?
If you're working in the microwave range, you might try sticking a three-port circulator into the feed, with a dummy load on the spare port.
A.
In electrics there is a device called a diode that is analogous to a check valve. It allows current flow in only one direction.
Unfortunately radio waves are Alternating Current. The current is reversing direction many times a second. Inserting a diode to allow current flow in one direction only will yield interesting results in the transmitted signal and similar interesting results in the received signal.
Bill
"Why not the best?"
Jimmy Carter
