tinashe8
- Nov 10, 2011
- 19
can someone help pliz. our ESP's are sturtevant type used for gas cleaning at an old thermal power station. we have a mechanical rectifier driven by a synchronous motor to provide unidirectional current to the electrodes. the mechanical rectifier is fed by a power transformer secondary winding. the primary winding is also connected to a voltage regulator. the mechanical rectifier is of the rotating blade type, rectifies the high tension single phase alternating current output of the main transformer to the unidirectional current required by the precipitator. now the question is we want to use thyristors, what modifications can we do and what equipment do we need to change this existing system or even circuit diagrams or any other possible systems that we can put in place.thanx
