In some electronic systems a resistive heating element can be installed. This may be able to maintain the internal temperature above the dew point so condensation cannot occur. I have seen those gold coloured, finned aluminium cased wire wound power resistors bolted to the inside of the instrument, and connected to the mains supply used in this way.
This additional internal heating may sometimes only be required while the equipment itself is powered down in some instances. The main on/off switch can energize the heating resistor in the off position.
I know nothing of aircraft systems, but have seen heaters used in underground mine electronic equipment, and marine applications where cold and damp are problematic.
The other solution is a hermetic enclosure and a silica gel pouch, some military equipment is like that.
