crshears
- Mar 23, 2013
- 1,881
Hello again all,
See thread238-361861 for background.
Do the mills ever gring slowly on this one...
Yesterday we held an Engineering Group meeting where the requirement for a galvanic isolator / isolating transformers was discussed; the retired electrical engineer mentioned in the above-noted thread was present, and advised that after seeing the information and recommendations provided in the thread referenced he remains totally unconvinced that there is any need whatever for the listed equipment, and persists in believing that solidly grounding the ship to the shore will eliminate all risk of galvanic corrosion between the ship and the shore.
Additionally, he does not seem greatly convinced that there is any cause for concern due to galvanic action regarding the use of more and less noble metals aboard the vessel herself, such as between her bronze propellor, brass stern tube, and steel hull, since she is floating in fresh water...
I am not keen on offending the gentleman, but if informed research indicates he is in the wrong, I feel I will have no option but to recommend proceeding against his sentiments.
Any further advice?
CR
Any further advice?
CR
