Vinzzzz
Materials
- Mar 24, 2009
- 21
Hi to all,
I'm preparing a Data Sheet for an Amine Regeneration Column. As i have studied and known the Amine process is very corrosive principally for two effects :
1- CO2 Corrosion;
2- Second Amine corrosion due to the product formed with CO2 and H2S (if present - in my case i have only CO2);
for this i have selected an AISI 316 Cladding on a low temp coloumn in order to avoid possible cracks in the Carbon steel welds. I have seen that to clad this coloumns it is used the ESW (electro slag weld) someone can show me how this technic function and if is possible use this technic for cladding of AISI materials? There are some other cladding Technics?
Thanks to all, with my regards Vincenzo Saviello.
1- CO2 Corrosion;
