Electrical Mystery
kthree
59
Just experienced an issue with a light switch on the wall in my house that I absolutely do not understand and would enjoy any comments any wish to offer. First off, electricity is not my thing. Lights, switches, and plugs I can handle but anything else is outside my expertise and definitely outside my comfort zone. With that in mind, buckle in, here we go. This house probably dates to the 50's, has hosted many different occupants, and I have now lived in it for just over 20 years. About a week ago, I flipped the wall switch and the ceiling light came on as always, but in a few seconds it began flickering. I flipped the switch off, waited a few seconds, and flipped the switch back on. Everything was good. Well, I'm sure you know where this is going... every time it took more switch flips to get the light to stay on without flickering. When it got to the point that it required me to push the toggle sideways to stop the flickering, it was definitely time to get serious about addressing the issue. When I went to remove the wall plate, I found an inlet cut into the molding to make room for the wall plate. The inlet wasn't exactly in the right place and the wall plate was forcing the switch sideways. Once I got the wall plate off, and without messing with the switch mounting in any way, the switch worked properly. But when I put the wall plate back into place, with the plate binding against the switch as before, the switch resumed not working properly. I tried backing the wall plate mounting screws out a bit in hopes of relieving some of the binding but even though I tried to convince myself the issue was better, it really wasn't. It was definitely time to replace the switch. After killing the circuit at the breaker box, I removed the wall plate again. Then, before replacing the switch, I simply pulled it out of the box enough to check to make sure the terminal screws were tight. It is a standard 2 pole switch, powering one light fixture, and both wires are black. The first terminal screw seemed quite tight enough. The other terminal screw wasn't loose but it turned a bit, probably less than a 1/16 of a turn. At that point, curiosity got the better of me, so I remounted the switch, sawed off about 1/4" of the bottom of the wall plate so it no longer touched the molding, and remounted it. Nothing appeared to be in a bind now. I reheated the circuit and came back and tested the switch. It worked great EXCEPT, now down is on and up is off! Why? I changed nothing. Has anyone else experienced something like this? Is this something to be concerned about? All suggestions, ideas, comments any wish to offer will be greatly appreciated. Thanks, K.
If your home is anything like mine (built in 1908), chances are the wiring does not reflect modern "color code" practice. Bottom line - you connected the "to the light" and the "to ground" wires backward on your switch. See following image. Those two black wires on the right side of the switch are the two I'm talking about. You can verify how they should be connected by looking at the switch casing closely: there is typically some marking that labels the four connection points (and there may even be an internal schematic on there as well, depending on the switch manufacturer).
Should you be concerned that "up = off"? Other than being an inconvenience, not really. In the larger scheme of things (i.e. for bigger industrial-grade switches and circuit breakers) the intent is that things fail in a "safe" mode - so if the contact spring or grip loosens and the switch drops down due to gravity, it should result in a "power off" mode. (Note that there is a similar requirement for electrical outlets - the ground/neutral pin location should always be below the two prongs. It isn't a hard-and-fast rule, but it is a useful convention, given the way most cables are run from the plug.)
You remounted the switch UPSIDE DOWN.
Tough love:
You shouldn't be doing this.
You are grossly incompetent.
By the way, code states;
'gravity must tend to open the switch.'
Up is on, down is off.
That is why it is illegal in the US (but not in Canada) to mount a breaker panel horizontally.
Ground pin location;
In Canada / code / trailer park feeder plugs: the ground pin must be uppermost.
Thank You Gr8blu and waross for considering and responding to my post. Both of your posts have been helpful to an amateur like me. In addition, my post pointed out one of my failings - my lousy communication skills. Obviously I failed to properly communicate that I didn't change anything. I didn't change out the switch or move any wires. I didn't even loosen the wires. All I did was unmount the switch and pull it out of the box just enough to get a screwdriver onto the terminal screws, check their tightness, then push the same switch, with the same wires in their same locations, back into the same box and remount it. The only thing I changed was to saw off the bottom 1/4" of the wall plate which ended the binding between the wall plate and the switch. I agree completely - it sounds ridiculous. What happened shouldn't have happened, shouldn't even be possible, but it did happen. Again, Thanks. I appreciate your consideration. K.
Any chance this is part of a multiway switch circuit for a hallway light, where the other switch changed status during your testing?
Only real possible cause here is that somehow when the switch was being forced into the box, the switch operated in reverse so that the mechanical action closed the contacts and now opens it when it works as it should and not being bent out of shape.
A picture or two might help....
