Giddleytwig
Computer
- Jul 31, 2025
- 1
Hello
I am trying to measure the distance between 2 pads in a 3DExperience CATIA EKL action using the distance function. But the distance function requires a body for both inputs. To convert the Pads to Body objects I am trying to extract a Surface from the pads and then measure the distance between each Surface. The Below code is what I have so far
I confirmed that SelectedObject has the pad. I confirmed that the List does contain a CATFace object as well, but when the code gets to the extract function i get the evaluation error
"Evaluation error
One mandatory input element is invalid, empty or missing. : extract"
After that it throws an error for the Notify saying that
"Evaluation error in when calling Notify - Attempt to read the attribut Name on an empty variable"
I know that the faceElement variable is resolving since I have printed it out and it is not NULL, and it is showing as the correct face for the pad I select, but for some reason extract wont take it as input no matter what I put for the second input. Any help with either solving the extract issue or helping with an alternative to the ultimate goal of measuring distance between 2 pads would be great.
Thanks!
Code:
let subElements(List)
//SelectedObject is a Pad selected from the product tree on running the EKL action
subElements = SelectedObject.GetSubElements(2)
let index(Integer)
for index = 1 while index < subElements.Size() {
let faceElement(CATFace)
Set faceElement = subElements.GetItem(index)
let surfaceElement(Surface)
set surfaceElement = extract(faceElement, 3)
Notify(surfaceElement.PrimaryType.Name)
"Evaluation error
Thanks!
