I do a eigenvalue buckling analysis of planar plate modelled with shell elements, I do two runs, one is a static run in which i apply force to my structure by a impactor & save the stress stiffness matrix and exit the, then re-enter with linear buckling analysis. The second run is an eigenvalue buckling run, in which I use the geometry deformed state(last state) from the first run & apply a very small perpendicular force. And i get eigenvalues and modes, eigenvalues are factors by which the applied load would be multiplied to get the eigenvalue buckling load.
My question is i did eigenvalue buckling analysis for 3 cases of steel qste 380, 420, and 460 grade steels, as information only plastic strains and yield point vary in these 3 different steels.
Buckling eigenvalue for steel 380 > 420 > 460 is it possible ? I expected steel 460 is stronger than 380 and required more eigenvalue buckling load to get the first deformation mode, but unfortunately its reversed steel 380 has higher eigenvalue than rest, i am clueless its possible ? please share your views.
