Spike,
Your foams and fabrics are likely to be difficult for handling and firing without additional processing in the form of shredding or pulverizing. As mentioned above, environmental issues are likely to be controlling factors that will determine the true economics of the proposed system. If chlorine or other troublesome substances are involved, then serious corrosion issues can be added to the list of potential physical and regulatory problems.
Bulk handling and transportation are likely to be troublesome to avoid contamination by water, dirt, or trash. What happens to the materials of your foams and fabrics when their temperature rises? Do they liquify, vaporize, become stringy or gooey, ...?
What about the potential to re-process these materials into some other form? Does simply firing them as power generation fuel really offer the greatest value? Are they necessarily combined, or can they be kept segregated for more coherent processing, transportation, and storage?
Are there daily, weekly, monthly, or seasonal variations in the quantities or proportions of these materials? Storage of raw or processed materials could be another matter of much consequence.
If firing these materials as fuels is really the best option, it seems most likely that either gasification or fluidized bed combustion will be the most practical options.
Since you seem to be looking to electric power generation as the ultimate use, it will be important to consider the value of that power. Peak, mid-range, and base-load power have greatly different values. If you are considering generating the power, you would do well to pay attention to the part-load efficiency of the power plant and not just its maximum efficiency. Start-up and standby fuel consumption of the power plant can also be major issues.
