I have recently done an E85 conversion on my Turbo Eclipse. This fuel is the best thing since sliced bread for high powered 4 bangers that are otherwise restricted on "premium" grade gasoline AKI ratings. One concern that I have is the long-term effects on the injectors. I sent an e-mail to RC engineering and they do not reccomend using E85 on their injectors, but if I must, they reccomend service every 3 months. I find that kind of excessive, but I'm by no means an authority on the subject.
Ethanol is a corrosive substance so I hear, but what corrosion would the injectors experience? Would this cause the pintle seats erode? The only differences I've found on Google between gasoline injecotrs and E85 is that the ethanol ones lean more on the ball type, whereas the gasoline typically uses the pintle. I can't verify any credibility on the source of that information, either.
The winter blend which is being served in my area is category 3 (70% Ethanol) at the moment for the record
