jennylong3
Chemical
I was wondering if anyone could help? In a closed pressure vessel, heating up a solution will obviously increase the pressure.
If the volume of solution is increased (the headspace reduced) prior to heating, and the same solution heated to the same temperature, will the pressure differ?
Thank you
Thank you
