If you are having arc furnace melting,then it is possible to further reduce P content. In induction furnace practice, the final P will remain unchanged. You must carefully select your charge.
I have not come across any failure due to high P content as long as it in within limits..
I have not failed. I've just found 10,000 ways that won't work." — Thomas Edison
_____________________________________
