1
- #1
ajk1
- Apr 22, 2011
- 1,791
The following is asked with respect to our ongoing review of all of our standard typical details, and not with respect to any particular project.
1. What is the standard cover that would be specified to the vertical downward hook of top bars in one-way slab at the floor edge supporting spandrel beam?
In other words, should the slab vertical hook be placed to the outside of the supporting beam top bars (which may in some cases require moving the beam top bars more away from the exterior face of the beam (depending on the slab bar diameter), or inside of those bars?
Would that be shown in the ACI Detailing Manual (a copy of which I can't find at the moment locate).
3. If the slab bottom bars were extended to the exterior face of the supporting spandrel beam and hooked up vertically with a standard hook, would it be appropriate to specify the same cover as the top bars?
