Eccentric in plane load on L shape weld
republic08
13
Hi Guys,
I need to check capacity of a "L" shape weld with an application of in plane eccentric load (Assuming an outrigger angle welded (L-Shape) to column with a vert load at end).
Can some help with a manual calculation for this case. I have tables from code, but no hand calcs to support that.
Thanks in advance.
Attach a sketch. I assume you are referring to a fillet weld on an angle clip, but can't be sure from your description.
I think the CERM covers this in the Weld Section if I remember right.
I also only showed the calc for the cg of the weld from the left, but the calc for the cg from the top is similar.
Hi republic08
Just use the formula at the site I gave you.
desertfox
