Earthquakes, is it a shock or random vibration event? 1
Twoballcane
951
Im looking at a spec and it describes the earthquake in a SRS (Gs vs Hz) profile, but I thought it would be described in a random vibe (G^2/Hz vs Hz) because earthquakes can last longer than typical shocks (pulse, velocity,…).
Any help would be greatly appreciated.
Tobalcane
"If you avoid failure, you also avoid success."
Earthquakes are neither of those strictly speaking, as they fall under their own "seismic" type event. The g vs Hz is a response spectrum converted from a time history using single DOF springs on masses. This gives a characteristic shape of spectrum, which shock or impact spectra differ from greatly. The seismic response spectrum will have in general the greatest (most damaging) energy associated with the 5-12 Hz range, whilst the shock/impact damaging frequency will generally be a lot higher (in 100+ Hz range). Industry standard in the nuclear industry for the analysis of systems/structures is to use response spectrum for seismic and time history for shock/impact.
See faq569-1083 for details on how to make best use of Eng-Tips.com
Thank you Drej for your response (no pun intended).
Tobalcane
Another question Drej, how would you run that on a shaker table? I mean would you use a G^2/Hz vs Hz profile to simulate the earthquake?
Thanks!
Tobalcane
No, G^2/Hz vs Hz is a Power Spectral Density input (PSD), which is generally a random vibration signal. You need to obtain either the time history (e.g. acceleration/velocity/displacement vs. time) for the event or the response spectrum (e.g. force/acceleration/velocity/displacement vs. Hz) to represent the seismic input. Whether you use one or the other depends on the results you need as well as computer resources.
Thanks Drej!
Tobalcane
