I am the in-charge to construct a small electrical facility in sandy area and the maximum acceptable (permissible) value for protective earth system is 10 ohms. For the first earth pit I use a copper rod 15mm diameter, 5 meters long in a hole 100mm diameter filled with Marconite/cement mix but the resistance value was 110 ohms (measured with TAGG/3 pins method).
Aprox. 200 meters distance from my earth pit a cathodic protection company had drilled a hole for deep groundbed of 170 meters and stem resistance value was found to be more than 1000 ohms.
Somebody have any idea to improve/reduce the earth pits resistance in sandy areas??
