I have a submersible 8kw pump protected by an earth leakage relay set at 30ma instantaneous. The pump starter 1000v supply has an earth leakage set at 200mA instantaneous.the 1000v volts comes from a 11kv/1000v skid muonted substation with an earth leakage set at 2A at the hv switch.water got into the pump contact block and the 11kv earth leakage set at 2A tripped first before the 200mA and 30mA.was it because of 3phase to ground fault.scratching my head coz as a sparkie I hve to give a repor.Help please.
