thrashercharged
Automotive
I'm not sure if this is the right forum for this, but I'm setting up an exhaust system for an engine dyno room and have questions. Here's what I have:
1. Room purpose - dynoing 4-cycle gas car engines, anything from 4 cyl to V8s, up to 1000HP or so, both blown and NA. No sustained durability tests, just quick ramp to redline pulls and some brief steady state at various rpms/loads for calibrating the engine.
2. We have residential neighbors within oh, 100 yards
3. The dyno room walls are poured 8" concrete
4. Room has conventional 10' drywall ceiling (hanging on resilant channel to avoid transmitting sound directly to trusses)with asphalt shingles outside.
5. We have (2) Nelson 300 dyno silencers (mufflers) 12" opening, side in, end out, about 30" in diameter, 112" tall rated 25-35 dB of silencing depending on frequency. Why 2 and why these particular mufflers? We found them on eBay and they were a good deal.
Our main goal is to operate the dyno as quietly as possible to keep the neighbors happy. Preferably, we'd rather that they not even know we're running a engine. I'll point the chimneys straight up.
My plan is to keep the mufflers inside to keep even more of the noise inside the concrete walls, stand the muffler on end and run a chimney through the ceiling/roof. The mufflers themselves should get plenty warm, but I think the room fans circulating the air 10x/min should be able to suck the heat out of the room sufficiently. How warm they'll get I don't know - anyone have any input on this?
Questions:
1. Since I have 2 of these mufflers, I might as well use both. Should I use them independently and run 2 chimneys? That is, give each bank of the engine it's own muffler?
What are the pros & cons of this setup? Will the muffler be too big for just a single bank (4 cyl at most) and not provide enough silencing? I ask this because of a statement from another dyno muffler's website:
"If the silencer is much too large, then the exhaust noise simply passes through using only the initial large expansion for attenuation."
- quote from
My understanding is that if the muffler is too big for the volume of exhaust input, the baffling inside isn't very effective and the muffler essentially becomes a large unbaffled chamber - is this correct?
2. Or should I put the 2 mufflers in series (I can easily do this by standing one up and laying one on its side and running its end output into the side input of the other.)
Will this provide more silencing? I realize this may increase the backpressure, but these mufflers are so large already, I'm thinking the increase in backpressure will be pretty small, but I'm no expert on this (which is why I'm asking these questions here!)
3. Question about exhaust temps. At the header, temps will be in the 1400-1600 *F range, but the muffler is a huge heat sink, so what are realistic temps at the chimney? How much lower?
4. Outlet sizing: My understanding is that the outlet should be smaller than the inlet for good sound attenuation. Both openings on my mufflers are 12". This probably already is overkill for the engines I'll be typically running, but just in case I get a blown big block or diesel I guess I'll be ready. I assume with the exhaust gases cooling, they'll have less volume and a smaller outlet pipe/chimney is ok and won't increase backpressure? Ideally, what size should my outlet & chimney be?
5. Another reason for wanting an 8" chimney is cost. A 12" double wall chimney stack is pretty expensive and custom while 8" double wall chimneys made for wood stoves and such are readily available. Would a double wall chimney rated for wood stoves and furnaces be ok to use?
After I get through the roof, the exhaust gases should have cooled even more, could I even adapt down to 6" for more attenuation or will this create too much backpressure? The reason for this is I'll need a raincap, and 6" is about the largest that are readily available, anything larger is custom again.
Thanks for any help. I think I've given all the info I can, but ask if I've left anything out.
Questions:
- quote from
