SriMat
- Jun 25, 2003
- 9
Dear friends,
I have this practical problem with maintaining the dynamic stability of a rotating (about vertical axis) hollow cylindrical shaft which has a concentrated load connected (rigid) to its 'free end'. The shaft is screwed on to a motor capable of rotating at various speeds.
Specifications are: Hollow shaft - Length: 80cm
Weight: 70 gms
ID - 0.5cm, OD - 0.8cm
Concentrated load - Length: 5cm
Weight: 70 gms
Cylinder OD: 1.6cm
Rotational speeds : 1rpm - 250 rpm
Whats making matters worse is that this 'free end' is actually immersed in liquids of different viscosities and densities. As you might know, the application I am talking about is for measuring viscosities of liquids.
I don't know how to determine the damping effect offered by the liquid, the downward axial force acting due to the weight of the (shaft+load) itself (and any corrections due to buoyancy effects) and their effects on the torsional load due to rotation in the liquid at various speeds.
The shaft starts making larger and larger circles when rotating at higher speeds (especially with low viscosity liquids), which I believe, is what is introducing a lot of errors into my measurements.
Sorry about the long post. Thanks a lot for reading on. I would be eagerly waiting to hear from you folks soon..
Cheers,
SriMat.
P.S: here is one paper I found - but not quite sufficient to help me -
Weight: 70 gms
Weight: 70 gms
Cylinder OD: 1.6cm
Cheers,
SriMat.
