Dynamic aerodynamics of the jet engine?
petar123
Computer
BG
Hello
For a small project I need a computer simulation of intake of air from a jet engine. Just how is sucked air and how will change the flow if it is a change of the design of the engine. I found the program Autodesk Flow Design, but it is not the air flow with the engine running. There could be a model with the engine running, but I do not know. So I write here. Basically that's what I need
but with dynamic indicators at different speed of the plane and most importantly - how the jet engine suck the air? What is the aerodynamics when jet engine sucks the air in defined hardware configuration?
Thank you!
Thanks for the reply!
How to do this or information on how to make?
