Maybe the more relevant question is , what is the minimum design temperature that the above steels can be used without the need for impact testing to establish a DBTT?
Reply; Go to ASME B&PV Code, Section VIII, Div 1 and what you will find are impact exemption curves that have been developed over the years for a group of steels, which the above are included, to ensure a minimum impact energy value for a given service temperature and material thickness.
-20 deg F if not normalized, and less than 0.5" in thickness
-55 deg F if normalized and less than 0.5" in thickness
If the thickness or use of the steel is below a minimum service temperature based on the exemption curves above, impact testing will be required to that heat of material.
