DUCTED FAN vs TURBOJET
harrisj
Automotive
GB
I am looking at the feasibility of a light (100 kg) low-speed (100 kt) unmanned aircraft, similar to those used by the military for drones, reconnaissance etc.
Most of these use small turbojets but I am considering using a ducted fan driven by a 4-stroke IC engine. What are the pros and cons? I guess fans are bigger diameter, but I don't know enough about limiting factors such as tip speed.
Can anyone point me to a useful source of data?
I can design such a fan for you. But it will be more complex and less effective than a propeller.
Ducted fan = high static thrust. Turbojets operate more efficiently at higher Mach # due to the "free" compression from the ram effect. You'll want to keep the tip speeds below the critical Mach # for the airfoil you choose for the blade.
Insideman:
We may be interested in getting you to help with the feasibility study / design. Please email your details to:
john.harris@marshallsv.com .
Here is a link you may be interested in:
They have built a ducted fan drone (I think they call it "Golden Eye"), with pretty impressive "advertised" performance. I have seen pictures that they have built one, but not actually flown it. The concept is a ducted fan, driven by a rotary engine.
Let me know what you think.
Grant Wittenborn
Aerospace Engineer
harrisj:
Here is a good reference, US patent #4,996,839. It's a patent for a ducted fan driven by a piston engine. Teledyne was evaluating such a configuration for long range, subsonic cruise missile propulsion.
You can also try this link:
Terry
