the other response is indeed more specific, and as cdxx says, you need to simply make calculation, assuming worst-case interior humidity scenario. is it not florida humid area?
as per any kind of codes, of course i'm not familiar with florida codes, but in generals it is fire codes that prescribe insulation in some cases, and energy efficiency coded in others, both are prescriptive if applicable.
we also did not learn if supply ducts serve for ventilation only or for cooling as well. i can hardly imaging that condensation is not an issue if duct serve for cooling - how high air flow rate you need to cool with relatively high air temperatures?!
un-elaborated request to apply more insulation resembles mentality of some contractors - they fear of condensation, are not familiar with calculations, but do not want to seek for professional advice.
