hello - i have a situation w/ a machine that i could use some help w/ - we have a rotating nut that is made of ductile iron that is binding in a steel bore which it sits in - our manufacturing facility machined the bore to the wrong finish & no lube was provided for the nut or bore - is there such a strip material on the same lines of garlocks "du" bushing material that can be glued into the existing bore - to re-machine the bore is a nightmare along w/ dis-assembly of the parts - - the nut is approx. 7" dia - any info would be greatly appreciated - thank you
