0
05735620d
Guest
I am trying to do a drop test, but I don't what wrong with my procedure, could you give me some advices? I have being done this simulation for a month...........
1. build two models, one for drop object, one for ground body
2.material assigned
3.set connection for ground body with"weld", set drop body with "free"
4. Initial condition: velosity set zero and height is 100mm
5. Gravity load : -9801 in the y-direction
6. contact region: select the surface of two body's contact position
I did it many and many time, but still not sucess, could you give me some advices?Please~~~~
And two error window come out after I press run~
Mechanica cannot proceed with the analysis because it could not open the geometry model database needed for contact regions or clearance measures.
Unable to communicate with the simulator. This probably means the simulator terminated unexpectedly. There may be more information in the
2.material assigned
