MacGyverS2000
I've read through several threads here about driving FETs with microcontrollers, but I'm still unsure of the best method. Some suggest pullups, some suggest pulldowns, others suggest driver transistors for maximum gate capacitance supply, etc.
Knowing that there's a "better" design for every different application, I won't ask "What's the best way?" I need to switch a mere 1-2A, in the microsecond range, etc. using a PIC. I believe most PICs can source/sink around 20mA on each I/O pin. It will be a logic-level FET (take your pick, although suggestions are gladly accepted) switching 12V into 2 LEDs and a resistor in series (Vf on the LEDs is around 4.5V each).
