I have a small 18"dia x 42"deep drilled sonotube pier being installed for a swing gate. Top of pier will be flush with grade. The gate will impart vertical axial load on the pier and a bending moment. No shear loads. IBC 2012 1807.3, equation 18-1, provides a depth calculation using lateral soil bearing pressure, diameter and applied lateral load. However, in this case, there is no lateral load, but bending moment instead. Is there a way to design the pier for a moment instead?
