Hi everyone,
When you have a chance, could you please take a look at my following questions and attached sketches (2 PDF files), and let me know your thought/ comments.
• Code: ASCE 7-10
• Ground snow load: 50 psf
• Ce = 1.0
• Ct = 1.0
• Is = 1.0
• Cs = 0.75 for 10:12 roof
• Cs = 1.0 for 7:10 roof
• Height difference between upper and lower roofs: 8’
• Rafter system roofs
• Sliding snow is not considered in this discussion/ calc
1. Lower roofs of Building 1, 2, 3 & 5 received same amount of drifting snow load regardless the pitch of upper or lower roofs. Does this make sense?
2. Building 3: Is it ok to use lu = 12’ (distance from ridge to eave) for drifting (leeward) snow load on lower roof (due to high pitch roof; >7:12)
3. Building 4: How one would combine drifting/ unbalanced SL for design of member (say beam/ header) at the common wall?
4. Building 6- Balanced snow load: Is balanced snow load (equal flat roof SL) within valley area ok?
5. Building 6 - Unbalanced snow load: Please comments
We have a copy of “Guide to the Snow Load Provisions of ASCE 7-05” by O’Rourke
Please point me to additional reference if you know.
Thank you,
Hdn32
• Code: ASCE 7-10
• Ce = 1.0
• Ct = 1.0
• Is = 1.0
Thank you,
Hdn32
