DRF_XYZ IN NX 7.5
DesEngineer4
IN
Hi all,
I am using the below journal for moving objects and features to specific layers. Now I want your help in moving this DRF_XYZ. Please see the attachments how i will create this DRF. My problem is when I executing this journal it is collecting these DRF`s as Datumaxis and moving to layer 40, as per code. But I need to move these DRF`s only to layer 100 and rest of all datumaxis should be in layer 40.
Code:
Option Strict Off
Imports System
Imports System.Collections
Imports NXOpen
Imports NXOpen.UF
Imports NXOpen.Utilities
Imports NXOpen.Assemblies
Imports NXOpen.Features
Module layermove
    Sub Main()
        Dim s As Session = Session.GetSession()
        Dim lw As ListingWindow = s.ListingWindow
        Dim ufs As UFSession = UFSession.GetUFSession()
        Dim workPart As Part = s.Parts.Work
        Dim displaypart As Part = s.Parts.Display
        Dim pointcol As PointCollection = workPart.Points
        Dim linecol As LineCollection = workPart.Lines
        Dim arccol As ArcCollection = workPart.Arcs
        Dim splinecol As SplineCollection = workPart.Splines
        Dim sketchcol As SketchCollection = workpart.Sketches
	Dim bodycol As BodyCollection = workpart.Bodies
        Dim allComp1 As ArrayList = New ArrayList
	Dim objArray(0) As DisplayableObject
	Dim pointslayer As Integer = 61
        Dim linelayer As Integer = 61
        Dim arclayer As Integer = 61
        Dim coniclayer As Integer = 61
        Dim splinelayer As Integer = 61
        Dim csyslayer As Integer = 40
        Dim daxislayer As Integer = 40
        Dim dplanelayer As Integer = 40
        Dim bodylayer As Integer = 1
        Dim sketchlayer As Integer = 20
        If pointcol.ToArray().Length > 0 Then
            For Each pt As Point In pointcol
                If (pt.Layer >79 or pt.Layer <60)
                ufs.Obj.SetLayer(pt.Tag, pointslayer)
              End If
	     Next
        End If
        If linecol.ToArray().Length > 0 Then
            For Each ln As Line In linecol
                If ((ln.Layer >79 or ln.Layer <60) and (ln.Layer >256 or ln.Layer <241) and ln.Layer >1 and (ln.layer >199 or ln.layer <80))
                ufs.Obj.SetLayer(ln.Tag, linelayer)
	      End If
            Next
        End If
        If arccol.ToArray().Length > 0 Then
            For Each arc1 As Arc In arccol
                If (arc1.Layer >79 or arc1.Layer <60 and (arc1.layer >199 or arc1.layer <80))
                ufs.Obj.SetLayer(arc1.Tag, arclayer)
              End If
            Next
        End If
        If splinecol.ToArray().Length > 0 Then
            For Each sp As Spline In splinecol
                If (sp.Layer >79 or sp.Layer <60 and (sp.layer >199 or sp.layer <80))
                ufs.Obj.SetLayer(sp.Tag, splinelayer)
               End If
            Next
        End If
         If bodycol.ToArray().Length > 0 Then
            For Each sb As Body In bodycol
		If (sb.Layer >19 and (sb.layer >199 or sb.layer <80)) Then
                ufs.Obj.SetLayer(sb.Tag,bodylayer)
		End If
	    Next
	End If
          For Each obj As DisplayableObject In workPart.Datums
            If TypeOf obj Is DatumPlane Then
                objArray(0) = obj
                workPart.Layers.MoveDisplayableObjects(dplanelayer, objArray)
            End If
            If TypeOf obj Is DatumAxis Then
                objArray(0) = obj
                workPart.Layers.MoveDisplayableObjects(daxislayer, objArray)
            End If
        Next
	 If sketchcol.ToArray().Length > 0 Then
            For Each sk As Sketch In sketchcol
                If ((sk.Layer >39 or sk.Layer <20) and (sk.layer >199 or sk.layer <80))
                ufs.Obj.SetLayer(sk.Tag, sketchlayer)
             End If
		sk.Activate(False)
		sk.UpdateGeometryDisplay()
		sk.Deactivate(False, Sketch.UpdateLevel.SketchOnly)
            Next
        End If
        Dim coniccol(-1) As Tag
        Dim conictype As Integer = 6
        Dim conictag As Tag = Tag.Null
        Dim count As Integer = 0
        ufs.Obj.CycleObjsInPart(workPart.Tag, conictype, conictag)
        While conictag <> Tag.Null
            ReDim Preserve coniccol(count)
            coniccol(count) = conictag
            count += 1
        End While
        If coniccol.Length > 0 Then
            For i As Integer = 0 To coniccol.Length - 1
                ufs.Obj.SetLayer(coniccol(i), coniclayer)
            Next
        End If
        Dim csyscol(-1) As Tag
        Dim csystype As Integer = 45
        Dim csystag As NXOpen.Tag = Tag.Null
        count = 0
        ufs.Obj.CycleObjsInPart(workPart.Tag, csystype, csystag)
        While csystag <> Tag.Null
            ReDim Preserve csyscol(count)
            csyscol(count) = csystag
            count += 1
        End While
        If csyscol.Length > 0 Then
            For i As Integer = 0 To csyscol.Length - 1
                ufs.Obj.SetLayer(csyscol(i), csyslayer)
            Next
        End If
        'move symbolic thread arcs to layer 1
	For each myFeature as Feature in workPart.Features
	    if myFeature.FeatureType = "SYMBOLIC_THREAD" then
	        for each myEnt as arc in myFeature.GetEntities
		    myEnt.Layer = 1
		    myEnt.RedisplayObject
		next
	    end if
	Next
        Dim root As Component = s.Parts.Display.ComponentAssembly.RootComponent
        If Not IsNothing(root) Then
        getAllComponents2(root, allComp1)
        Dim dispobj As DisplayableObject = Nothing
        Dim cnt1 As Integer = allComp1.Count
        Dim objectArray1(cnt1 - 1) As DisplayableObject
        Dim objlayer As Integer = Nothing
        Dim cnt2 As Integer = 0
        For i As Integer = 0 To cnt1 - 1
            dispobj = DirectCast(allComp1(i), DisplayableObject)
            objlayer = dispobj.Layer
            If (objlayer > 19 and (objlayer >199 or objlayer <80))  Then
                ReDim Preserve objectArray1(cnt2)
                objectArray1(cnt2) = allComp1(i)
                cnt2 += 1
            End If
        Next
        If cnt2 > 0 Then
            displaypart.Layers.MoveDisplayableObjects(1, objectArray1)
        End If
     End If
    End Sub
    Sub getAllComponents2(ByVal comp As Component, ByRef allComp As ArrayList)
        Dim child As Component = Nothing
        Dim space As String = Nothing
        For Each child In comp.GetChildren()
            allComp.Add(child)
            getAllComponents2(child, allComp)
        Next
        End Sub
    Public Function GetUnloadOption(ByVal dummy As String) As Integer
        'Unloads the image immediately after execution within NX
        GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Immediately
    End Function
End Module
Thanks & Regards,
Sam
Those are called coordinate systems (or csys for short). Your code already handles moving these objects, it is currently set to move them to layer 40.
Change the line:
Code:
to:
Code:
Dim csyslayer As Integer = 100
www.nxjournaling.com
Please see the attachment... (this is for reference only)
Hi cowski,
1. The datums which are in part navigator should be in layer 40, and DRF`s which i circled in work interface they should be in layer 100.
2. (for our previous conversation about to hide datums in work interface)
As these DRF are collection as datums and moving to layer 40. But I need to visible these DRF on model. As you said in our to create a journal to turn off the layer.. Then, these DRF`s will not visible..
Thanks & Regards,
Sam
 http://files.engineering.com/getfile.aspx?folder=a4f6087d-e57d-4c3c-8d75-49bed49470a0&file=iMAGE.JPG
The coordinate systems are not features (they do NOT show up in the part navigator). If you made my suggested change to your journal and ran it, the circled coordinate systems will now be on layer 100 (turn layer 100 on/off or do Information -> object to verify).
Incorrect. These are coordinate system objects that are separate from datums. They have a separate collection called CoordinateSystems. Your journal handles these objects (though not through the collection) and explicitly moves them to layer 40. Change the line I referenced in my previous post to move them to layer 100 instead.
ok thanks, I will try now and let you know..
Thanks & Regards,
Sam
