Drawing view naming irritation 1
maxh3
When creating section and detail views Solidworks automatically names the view with the next letter in the alphabet after the last view it named. However, if I delete one of the views, Solidworks doesn't "recycle" that name, so every time I create a view from then on I have to manually rename it if I don't want a gap in the letters. This is kind of irritating. Does this bother anyone else?
You can adjust this in the sheet properties, under "Next view label".
Excellent, thanks! That sure was an easy fix.
It's 'after the fact' I think, but you can click the button 'Manual View Label' - and name it whatever you want.
SW Premium 2011
64 bit SP4.0
Intel Xenon X5650 @2.67GHz
2.66 GHz 11.9 GB of RAM
