Is there a way to dimension the lines in a title block, but have the dimensions NOT visible when not in the "Edit Sheet Format"?
I am trying to define the location of the lines that comprise the areas of the title block. So far, I have been dimensioning them to get them to the exact location I want them at, then deleting the dimension and applying a "Fix" constraint to the line. Or I have input the X-Y coordinates of the points then applied a "Fix" constraint.
I am looking for a way to "hide" the dimensions when NOT in the "Edit Sheet Format" mode, similar to the way AutoCAD uses the Defpoints layer...
Air cooled, belt fed, gas operated machine gun firing from the open-bolt position
