Hi All,
I have come across two drawing standards for structural engineering plans.
1. For a framing plan the section is cut just below the floor looking up. That way, all the supporting beams are shown as solid lines and load bearing walls and their openings are shown clearly
2. For the same plan the section is cut above the floor looking down. That way the supporting beams and walls are shown as dashed lines.
I've tried using the former standard since it shows the supports more clearly and openings in load bearing walls are not lost. Where I work, there are more British/European trained architects who have an extremely hard time following through this standard.
Is one standard more North American while the other more European? Just want to know your thoughts on these.
