are you printing to pdf or exporting to pdf? I seem to remember having some issues a few years back with it adjusting when I printed to pdf (i.e. plot -> cutepdf) rather than hitting the export and configuring the pdf settings and doing it there.
If you trying to get .pdf by exporting .drw, use Save as -> choose .pdf extension -> set preffered settings (monochrome, open after creating, etc.)-> OK.
Only tip here is to set WD to desired place where you can find your drawing in .pdf format.
