"But were you able to apply it in reference to another line??? I cant seem to figure that part out... "
If you have a line at some non-even number angle, an easy way to make a line a certain angle relative to it is to copy the line, pick its start as the base point ("From" point), then pick its end point as the "To" point.
Now you have what appears to be a single line, twice as long as the original. But it is actually 2 lines, thus you can select the 2nd line (the copy) and Rotate it. "Rotate" command, select the 2nd line, pick on the point that is the end of the 1st line/start of the 2nd as the Pivot Point (Center point or "Rotate About" point), then enter the angle you want it rotated.
I use circles to define line lengths many times. If your rotated line is longer than you want it, draw a circle from the start point of the line, with a radius equal to the length you want, then Trim off the excess. Then Erase the circle.
Or, if you need it longer, draw the circle, then Extend to it.
