I'm currently in the middle of a discussion between another engineer and the operator of an agricultural irrigation system on how to winterize the system. The pipeline is predominantly 14" PVC installed to grade so that water will drain to the designed low points. The discussion is over what to do at those low points. The simple solution is to install a riser to the ground surface with the ability to remove a cap and pump out each low point/drain in the fall.
The other proposed option is actually what was installed on the operator's previous system (lease of the pump site was ending and needed to move to a different site requiring new main pipeline). This option is to install a saddle on the large diameter pipe with a 2" brass pipe coming off the bottom, running horizontally to the side with a curb stop installed followed by another 2" section of pipe that runs to the surface with a cap on it. The theory behind this is to allow for compressed air to be used to force the water through that 2" pipe and up to the surface.
Honestly, both of these systems make sense to me. The other engineer is of the mind that air will not force the water through the 2" pipe. The resources they've shown me, however, are in relation to home/golf irrigation systems where they were not installed to grade and are attempting to force the water up through the nozzles. This process requires that air move fast enough to suspend water particles and force them up through the nozzles. I'm not sure this applies to what we're discussing on this project, however, as the drain detail would simply require the air pressure be enough such that it could force the water through the required elevation head to the surface.
I'm hoping that someone here can provide some clarity on this discussion, preferably with some references or other resources (other engineers here respond better to technical resources). Any information would help though.
I've attached the drain detail from the design of the previous system for reference.
Thanks!
Thanks!
