For drains where there are pvc tube inside concrete.. what do you use for waterproofing to ensure water won't enter the sides (in between the pipe and concrete)? We usually use asphalt membrane enclosing the tube end on surface of drain but we can't use it in a particular case. Is there some kind of bonding or waterproof liquid you can put around the drain so water won't seep in the perimeter?
