I inadvertently changed the font in a block attribute to bold and now I cannot undo this. Where can I edit the font characteristics? Also, where are the blocks saved. Thanks.
If you do not you use the function WBLOCK, then the block is stored internally in the drawing. You should explode block, change the parameters of text and create a new.
