I'm having trouble getting smooth lines, especially for circles, in the drafting application. However, there is no problem in the modeling application. See the attached image to see the same object in both applications. As you can see, the circles in Drafting are jagged, and is the case even after Regenerate. NX seems to automatically increase the resolution as you zoom in the drawing, but I would like to control the resolution to force the curves to be even smoother.
Is there a setting that controls the "smoothness" of curves in Drafting? Prefs>Visualization>Line>Curve Tolerance makes no difference.
NX9 Win8.1 64bit i7-3770K 16GB Quadro2000
