You shouldn't dimension in an isometric view because it doesn't show true size and shape and you can't dimension to a "hidden" feature. Cut views, section views, etc. are all okay as long as it is clear what the feature is that you are dimensioning (true size and shape).
You can find everything you need to know about section views in Multi and Secional View Drawings ASME/ANSI Y14.3. It's a good buy. I'm currently redesigning a high speed miniture mechanism and was looking at the drawings. I found numerous mistakes: wrong projections, wrong callouts, dimensions to hidden lines and the granddaddy of them all a section view with hidden lines
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 5.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NVIDIA Quadro FX 1400
o
_`\(,_
(_)/ (_)
Never argue with an idiot. They'll bring you down to their level and beat you with experience every time.
It depends on which standard you are refering to, and whether you are using board drawings or CAD drawings of solid models. ASME Y14.41-2003 definitely allows dimensioning to axonometric views (which are similar to iso views) on the drawing.
I prefer sections to use of hidden line most of the time, I thought it was in a standard somewhere that sections etc are preferable but I couldn't find it last time I looked.
aardvarkdw,
I'm with you on ISO views but in my post the other day people seemed to think 14.41 might allow this.
Not only are sections preferable, but dimensioning to hidden lines is not a preferable method per Y14.5. Para "Dimensions should be shown in true profile and refer to visible outlines."
In some cases it is ok to dim to a "hidden" line, by drawing a broken out section, that makes the "hidden" line visible... but you should use this method discretely.
Wes C.
------------------------------ When they broke open molecules, they found they were only stuffed with atoms. But when they broke open atoms, they found them stuffed with explosions...
Chris,
Was he requiring three views or just as many views as nessesary?
ewh,
I agree there are times when dimensions are allowable in iso or axo views as with ASME y14.41 but that I believe refers only to 3d models not to 2d drawings. I may be wrong on that, as I've mentioned in other threads I am still working on getting a copy of the y14 series here.
