draftin design standard switch
NikonF6
Automotive
Aug 21, 2013
165
I changed the design standard and gave it name, in customer default. When I open old model, still old drawing-standard is active.
How I can switch the standard?
Did you restart NX afterwards? Customer Defaults do not take effect until you restart NX.
Tim Flater
NX Designer
NX 9.0.3.4 Win7 Pro x64 SP1
Intel Xeon 2.53 GHz 6GB RAM
NVIDIA Quadro 4000 2GB
Simply making a change in the customer defaults won't affect existing drawings; the settings are saved in the file preferences. However, you can inherit the customer default settings into an existing file. Open the file of interest and go into the drafting preferences; look for an "inherit" option (location may differ depending on what version of NX you are using).
www.nxjournaling.com
I use NX7.5
NX has been reset
While in drawing, Preference, drafting, drawing setting (use setting from standard)
But still is active the old standard
I did once change to the new standard but did not write down the procedure.
So how I can activate the new standard
While in Drafting, go to...
Tools -> Drafting Standard...
Now this will only effect that next dimension/annotation created. If you're looking to update any existing drafting objects, they will have to be explicitly edited to that effect.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
